Pisound reviews
Really happy with the Pisound overall, the audio quality is clean, MIDI works great out of the box, and the form factor is exactly what I needed for a Pi-based project. Patchbox OS integration is a nice touch too.
One thing that would push this over the top for me personally: CV I/O. I build custom circuit boards and being able to send and receive control voltage directly through the board, without needing external adapters, would open up a lot of possibilities for hardware integration. It is the one gap between the Pisound and a truly universal Pi audio/control hub for DIY projects.
I use it as a sound card for headphone output. I have to say that the overall quality is good; before switching to USB, I also used the MIDI interface and found it satisfactory. It would be nice to have a slightly nicer looking case.
Absolutely brilliant – I run all my guitar effects through it now… using Ardour as a DAW weirdly enough. The whole thing can run headless though.
I’ll probably be getting another one at some point… they’re cheap enough to have an entire unit just as a hot-swapable backup.
If you are thinking of an upgrade, I could really do with 4 outputs. Kindof a Focusrite 2i4 kindof a deal.
The interface has a nice formfactor and the fact that I could get it up and running with a custom Yocto-built Linux OS is a huge ‘+’.
However, my plan was to pair it with my custom DSP-software for guitar effect processing and it has too low headroom for my active humbuckers, even when I lower the gain to the lowest. I will have to create a custom curcuit to fix this so I haven’t really tested it’s noise level which is a big deal to me (lots of distortion tends to increase the noise 😛 ).
It may be that if I have to create a custom pcb for the analogue frontend anyway, the PiSound Micro might fit my needs better.
I use it for a guitar to MIDI project. I play a single note on the guitar and the according chord with the seleced sound is played. The PiSound makes an additional USB MIDI adapter obsolete. I also use some of the header pins for switching patches forwards and backwards. I also wanted to use the I²C interface for a small 16×2 LED display (to replace tha large touch screen) but it was already in use by PiSound.
The I²C pins are actually available for your use and are not used by Pisound. Feel free to contact us or post on our community and we’ll help you out.
It’s just an input pad away from being perfect.
The input was clipping at zero gain when I had a guitar with medium output passive pickups, so I had to spend some time making my own -6 dB attenuator circuit for the input. I think it should be fairly easy to have a pad integrated and let it be toggled either via software or a mechanical switch.
Apart from that, I’m very happy with it and I find it very convenient and useful for my guitar pedalboard. The box to the left of the Pisound in the picture contains the homemade pad and also merges 2x mono channels to 1x stereo.
Pisound is a great idea overall, but to me it feels like a beta version of a product that the developers got bored with. Overall, I would say if you want to use the core functionality that comes with Patchbox OS (MODEP, Orac, PD) it is a great device. And if you know what you’re doing with linux and have other specific plans, this will get you the nice i/o and the button functionality.
There’s one button, why not make it a nicer one? A standard keycap button would work fine. The acrylic case definitely needs updating to something better. For example it has a known issue (you can see the developers replying to comments about this online) where a lot of USB-C plugs won’t fit through the hole provided. I have to run mine with that side of the case off. But the answer seems to be “use a file to make the hole bigger” rather than releasing a revised case design. (I’ve also requested vector files for the case so I could modify it and cut my own but gotten no response.) Check out the hardware for the ShieldXL to see where they should be heading in a (hopefully to be released) Pisound v2.
The community unfortunately seems pretty dead, and there is very little engagement from the developers on simple issues people post on there. They seemed pretty involved until about 2020 from what I can tell.
There are also numerous ways the user interface could be improved, but this review is getting too long already! In sum, it’s a cool device, and I’m still happy I got it. If the developers seemed a little more interested/involved, and did a few revisions, it could be amazing.
Great project!
Thanks to you, it’s easy to build a massive multi effect pedal board with billions of possabilities.
All whats left to solve for me, is the power supply for cooling. I use an USB plug, but it would be great to plug onto some pins inside the (self build) case (which are now occupied by the HAT). Else you could invent, append, recommend cooling and/or a case with sufficient space for common cooling opportunaties supplied at the big A.
Many thanks for your work! Keep in going! Check out and support pipedal if possible and/or neccessary.
Cheers
functions as described and the after-sale support is great. got a fully-functional looper here thanks to the pisound and looperlative folks.
Great device. Improvements- This should be able to be mounted within a housing, with the midi io at a right angle to the audio io it is very hard to mount in a sane way. Put the midi Io on a daughter board with cable. Then any mounting config can be used.
Also the unit does not fit on a pi5 with modern active cooling. Sound wise- the best io for a PI.
I bought the Pisound for a specific project – to get Pianoteq running on a “standalone box” rather than running from my Mac. All I can say is that it just works perfectly! Sturdy build, easy to assemble and really no issues at all. I’m very happy with the whole package 🙂
An essential Hat to get a pro result. Really amazed by this small and so efficient thing ! So efficient that i bouht a second Pisound and a Midihub that perfectly works too.
My only pb (but maybe it’s only my lack of knowledge) is the very fast increasing level on the audio input : only a few millimeters up on the gain knob and my guitars are too loud and light the red led.
The second pb is that Modep midi learning only react to my CC midi messages (great for volume and effects pedals) and not the static ones (Program changes, notes on-off, …) so that it is impossible for me to change patches and more important to activate a looper.
I use my Pisound MidiHub software to check if messages goes in and out and it sees them racting. So this is probably Modep that has a problem.
Giedrius, does any of your users gets the same strange limitation ?
Thank you
Pisound has a particular gain curve to accommodate a wide range of devices you may connect to it. If possible, slightly reduce your guitar output level, so the gain knob has a wider working range.
It is possible to make MODEP respond to Program Change messages, see https://community.blokas.io/t/issue-in-pedalboard-change-using-midi-program-change/4580/9 or related topics.
Secret Saucey Sonic Sorcery.
I use it for guitar effects and to create custom effects patches aka experimental signal manipulating using Pure Data (which comes packaged with PatchOS). Avoided having to buy a Stomp or one of those Zoom CDR pedals after discovering this product! I found some inexpensive, used MIDI controllers online to compliment it. No latency issues so far, even with a modest-sized virtual pedalboard, and it’s been rock-solid reliable. Also, you can use a stereo Y-splitter to split effects chains into front of a amp and then into effects loop of your amp, so it can integrate well with your physical rig if not doing straight-up modeling.
Works perfectly, fast delivery. Great possibilities with this. The case is also nice!
Really great device and exactly what I needed, with stereo input/output as well as midi support.
Keep it up!
I, too, find Pisound works very well, but I will not add any more positive reviews regarding Pisound or Patchbox; you can read enough on this page. I want to make a very positive judgment about the support that Blokas offers, I am talking about Giedrius: a patient and competent person who makes it possible for even inexperienced users to be able to use Pisound at its best. Thank you !
pisound is the best 2×2 dedicated RPi soundcard on market. If you are building your own portable stereo musical instrument or (guitar) audio multi effect processor, Pisound is the most reasonable option.
I am using the Pisound with Rpi 5 and Modep. I have never used such a versatile and high quality ‘pedlaboard’. It is really amazing. Great sound, easy to use and also controllable through midi. I am using a Behringer FCB1010 with a Uno chip. It works great after some tweaking and understanding how things work with switching pedalboards over midi (Web UI can not be running or been running). With amp modelling it sounds really good for my use case. I can create any ‘sound’ I need.
So far it’s working well enough, but the app is not working.
Purchased Pisound end of 2023, especially due to the combination of standard midi in/out and 2-channel audio in/out.
My goal was to have a very portable Hammond B3 clone module by using setBfree on Raspberry Pi headless.
With Pisound it has the right audio quality to compete with commercial clonewheels.
As a newcomer on linux it took me a while to get around with the system. But now it works perfectly. The Modep pedalboard concept, which can also be used with setBfree, is awesome. I can control setBfree with my smartphone and/or with my midi controllers.
Amazing device that revolutionized my audio setup! I’m using it headless with SuperCollider, some MIDI controllers and Open Stage Control server, and I must say I am truly blessed. Just wish there was a 64bit Patchbox OS version (with RT kernel) with full support (and a case) for the Raspberry Pi5 (but I guess this is all coming soon), and that would be the most awesome device in the universe!
Awesome device and team behind it!
Very impressed by the quick response to my questions by BLOKAS customer support via the Forum. I see that people are beginning to explore running with RPi5. Will keep following to see when that makes it out of beta for us newbies.
Very practical to have a setup running SuperCollider patches as installations or for performances with good audio quality 🙂
Using it as standalone with Pianoteq, it is a pleasure with it
I’ve been using Pure Data and SuperCollider in my music projects and am migrating to a headless setup. The documentation on the website is complete and the OS comes loaded with examples. The power to auto-launch your patches from such a small piece of equipment is incredibely satisfying. Sound quality is great!
My first attempt to go headless with Raspberry Pi for Music. First of all the Button is a genius concept to make things easy. Furthermore it comes with excellent sound quality. I also got me the case which makes things super smooth. An additional bonus is that my CME Widi bluetooth adapters are working with Pisound. Now I’m experimenting with Orac. Life is good.
Pisound opened up a whole new world of audio effects coding and creation. It has worked flawlessly, and is ridiculously powerful when combined with the patchbox os which is a joy to use. Once you pop you can’t stop!
I am using pisound together with the translucent case and it is just great. I also installed reaper on it and it works flawlessly. I just love it.
I’m a very happy user of Pisound. My current guitar pedalboard is a combination of my favorite overdrive/gain pedals and Pisound with MODEP. The sound quality is great and PatchboxOS makes Pisound the best audio hat for Pi. The only thing I’m missing is separated L/R jacks for the stereo input and output.
Excellent sound quality combined with open source audio platform opens huge creative possibilities. From soundfont sample player (pianos, percussion, etc), to hosting neural amp modeler for my guitar rig, this transforms pi4 into low priced music marvel tool. Especially when combined to preferable MIDI controller and/or foot switch. Latency is very low.
Awesome device. Excellent audio quality. Low latency. And coupled with the Patchbox OS really easy and versatile in its use.
My only feedback would be about the rigid geometry and placement of the inputs, outputs and pots. I would love if there would be a bare-bones model, where you could solder your own 40 pins GPIO connection to. (So you can choose whether to connect it as HAT shield directly, or via a 40 pins flat cable). Same for the inputs, outputs and pots. I rather solder JST connections to the board and then wire these to a separate interface panel.
It’s a fantastic product that does exactly what it promises. I attached it to a Raspberry Pi 4, and I installed Cockos Reaper for use in my solo live shows. It is capable of running multiple lv2 effects and playing backing tracks while recording in full stereo, at 96kHz/24 bits, with about 2 or 3ms latency. There have been no pops or cracks, no dropouts, no trouble with any kind. And the preamps sound better than my PC USB audio interface (Komplete Audio 6). You can hear the end result on my YouTube channel, waruta69.
Ah sure shipping was quick, product is a one of a kind plug and play. Staff are helpful. The only possible downside could be the lack of raspberry pi’s available and thats well out of their control
Used for a virtual pipe organ software, and this was the best money I have spent on this entire project. I originally tried a USB to MIDI adapter, but the latency was significant, throughput was shit. I bought the pisound hat, and there is little to no latency, and no other errors resulting in a high quality, functional setup. Well worth the money.
Buying another. Favorite RPi audio hat by miles. Shipping speed to US is shockingly fast. So versatile and audio quality is excellent.
the Pisound is such a crucial component to any Pi-based setup. the ease of configuration with Patchbox OS and the massive boost to sound quality are so welcome! thank you for building this approachable lil’ workhorse!!
Awesome little thing.
Made a build with a raspberry pi 4, now its my go to box when playing or recording some ideas.
Very good sound quality and super low latency. Also customer support is very fast and friendly.
Tout est super fonctionnel avec patch os. L’os windows 10 pour arm peut-il être stable avec le pisound et raspb pi 4 4go?
Hi Thomas, there’s no Windows 10 driver for Pisound, it won’t work without it.
Awesome piece of gear. I have had a blast with it. Lead me to go buy a MODDUO. I just rebuilt it on a Pi 4 and will use for midi instrument. LOVE IT.
Really great hardware. I have been using it for personal software development projects for about a year now. Will probably buy another Pisound in the future.
Great hardware and sound, software is ok but could be better. Modep for exemple is under the real modduo software. Cool to use with Pianoteq and some synths.
Setting up my first little home recording studio, I found Pisound easy to handle. It has a very good sound quality and I enjoy using it very much.
Excellent sound quality and latency !
Great to have jacks and not RCA
Balanced output would have been perfect
superb quality, almost zero latency audio board for raspberry pi, very well supported by blokas people. highly recommended for any audio raspberry pi project
I like a lot my pisound. I was intending to use it for music and effects but now it is for volumio. Anyway the sound quality is very good. A detail that you could fix is that the acrilic feet have little adherence to any surface.
Excellent HAT soundcard for the Raspberry Pi. I use with the Jambox OS to plug in my instruments and run Jamulus for online live music playing. Setting it up was easy, the sound quality is excellent, the latency is very low, and everything fits in a neat box. My only suggestion for improvement is the box itself, which is a little hard to build, and the hole for the power supply cable is too small to fit the standard RPi plug
Pisound is the best audio card for Raspberry Pi. Period. Pair it with Patchbox OS and you have a dead simple setup that can be a host for MidiHub, a multi-effects unit for guitar, a synth – and that’s just the stuff that’s easy to set up!
Awesome device I own 2. I couldn’t get enough so I had to buy another. Modep (creators of the Modduo), on one and Orac (Mark Harris is amazing) on the other. You can’t beat it with a stick. Sounds are amazing either what you put in, process, or what comes out through exploration. Thank you for all the hard work very much appreciated.:) AAA++++
One of the best Raspberry Pi audio interfaces for low latency and high quality i/o.
I have barely scratched the surface of what it can do. But overall sound quality and latency performance is great.
I’m very happy with the Pisound. That being said, it could use more physical buttons and/or better Android interaction.
Pisound is great. I used to build an augmented glove that controls voices from a microphone. I easly programmed it with Pure Data. Super easy, super fun!
Ive a couple of PiSounds , excellent way to add decent audio and midi to your Pi.
Another important aspect of PiSound is that Blokas provide a ready to go OS (patchbox) and a proper support channel.
This is in stark contrast to the ‘common’ diy rPI situation where you are left to scour the internet for solutions to try to work out how to get you soundcard working optimally with raspbian etc
Fantastic device. Clean and elegant way of getting audio into a Pi without running USB cables etc, with superb latency and sound quality.
I’d love to see an XLR version!
Pisound allowed me to prototype my HW Audio device idea really easily.
I have two piSound equipped Raspberry Pis with 7″ touch screens and PianoTek software that I use as the sound engine for 88-key MIDI keyboards. I push one button to power up and launch the application. Great grand piano sound. It took a little trial and error to get everything working together but worth the effort. I got a Pi 3 working and then built another unit with a Pi 4.
Discovery Modep was awesome and adding the PiSound made the experience even better! PiSound is well built and the installation instructions are very clear. I’m using Pisound to replace an aging pedal board for my live bass rig. Do yourself a favor and order the acrylic case as well. If you have a RPi 4 I also suggest getting a Pimorini fan shim. Extremely pleased with my purchase!
I really enjoyed the results of my pisound project. It is a simple guitar rig that includes a pi5, running nam captures with pipedal.
I had a few doubts and the team was very helpful answering my emails.
So, thumbs up. If wasn’t the taxes, I would get another one
